Điện thoại Nokia X6
Thảo luận trong 'Điện thoại Android' bắt đầu bởi Hi.2019, 25 Tháng mười hai 2018.
  1. Hi.2019
    Hi.2019 New Member
    Điện thoại Nokia X6 (2018) 4g Ram - 64 Gb
    giá 4.490.000 đ
    Nguyên Seal , Bảo hành 12 tháng
    Network
    Technology GSM / CDMA / HSPA / LTE
    Launch Announced 2018, July
    Status Available. Released 2018, August
    Body Dimensions 147.2 x 71 x 8 mm (5.80 x 2.80 x 0.31 in)
    Weight 151 g (5.33 oz)
    Build Front/back glass (Gorilla Glass 3), aluminum frame
    SIM Hybrid Dual SIM (Nano-SIM, dual stand-by)
    Display Type IPS LCD capacitive touchscreen, 16M colors
    Size 5.8 inches, 85.1 cm2 (~81.5% screen-to-body ratio)
    Resolution 1080 x 2280 pixels, 19:9 ratio (~432 ppi density)
    Multitouch Yes
    Protection Corning Gorilla Glass 3
    Platform OS Android 8.1 (Oreo), upgradable to Android 9.0 (Pie); Android One
    Chipset Qualcomm SDM636 Snapdragon 636 (14 nm)
    CPU Octa-core 1.8 GHz Kryo 260
    GPU Adreno 509
    Memory Card slot microSD, up to 400 GB (uses SIM 2 slot)
    Internal 64 GB, 4 GB RAM (6.1 Plus)
    64 GB, 4/6 GB RAM or 32 GB, 4 GB RAM (X6)
    Main Camera Dual 16 MP, f/2.0, 1.0µm, PDAF
    5 MP, f/2.4, 1.12µm, depth sensor
    Features Dual-LED dual-tone flash, panorama, HDR
    Video 2160p@30fps, 1080p@30fps (gyro-EIS)
    Selfie camera Single 16 MP, f/2.0, 1/3.1", 1.0µm
    Video 1080p@30fps
    Sound Alert types Vibration; MP3, WAV ringtones
    Loudspeaker Yes
    3.5mm jack Yes
    - Active noise cancellation with dedicated mic
    Comms WLAN Wi-Fi 802.11 a/b/g/n/ac, dual-band, WiFi Direct, hotspot
    Bluetooth 5.0, A2DP, LE
    GPS Yes, with A-GPS, GLONASS, BDS
    Radio FM radio
    USB 2.0, Type-C 1.0 reversible connector, USB On-The-Go
    Features Sensors Fingerprint (rear-mounted), accelerometer, gyro, proximity, compass
    Messaging SMS(threaded view), MMS, Email, Push Email, IM
    Browser HTML5
    - Fast battery charging (Quick Charge 3.0)
    - MP4/H.264 player
    - MP3/WAV/eAAC+/FLAC player
    - Photo/video editor
    - Document viewer
    Battery Non-removable Li-Ion 3060 mAh battery
    Misc Colors Black, Blue, White
    SAR EU 0.94 W/kg (head) 1.82 W/kg (body)
: nokia x6
